on the right side is the same objekt like on the left side or in the middle. I tried an other AMS Slot, New sealed PLA and calibrated everything i can. I even tried to print it slower with more infil. The only think i dindt changed the nozzle. I ordered now one to check if my nozzle is just to old.
English is not my first language so i dont know how i should search for this problem sorry for opening a new topic. Maybe someone can help me.
Ok now it looks like my Nozzle is now complete dead? I have to admit i got my p1s last year at my birthday 24 august. So i nearly used the nozzle a whole year and i think i printed over 20 KG with it.
The Filament is new. i tried 3 different Spools so i dont think it is tangled. I will tomorrow try to look in the hoses for some Filament. Is there a way to clean the nozzle?
If it was me, I’d turn the nozzle to 300* & run some cleaning filament through it…a lot of it. Myself, I don’t believe in using the nozzle needles.
You can also do 3-4 cold pulls.
What ist cleaning Filament? Ok i found some Cleaning Filament but it cost nearly the same like a new nozzle I will try to clean it by hand a bit and maybe buy some of these cleaning Filament. Thank you Lion
Set the hotend to a temp 10* or hotter to what you were last printing at.
Run it through the nozzle maybe 300mm. Pull off Purge, let the cleaning filament sit for 5 min. Turn down hotend to 0. Restart Hotend & when it reaches about 70-90* do a cold pull. Do this a couple of times.
