Good morning, I’ve come to the same conclusion that it’s a design issue since I’ve seen other people with the same model, and they got the same result.
Thank you all very much for your help!
To dispel any doubt I printed the same model with A1/P1/ a Delta and Voron printer, modifying the parameters, in some cases I obtained an improvement but the anomaly is always more or less present, always in the same point… So yes, I believe that the problem is the g_code of the drawing and not the printers or the settings… If one has an error, it could be a coincidence, when two or several have the same problem, it is no longer a coincidence …
