In my points/transaction list I see
Now I want to know which of my print profiles is causing this problem and also it would be nice to know whats wrong with it.
@MakerWorld can we please see more details there in the future, so that we can fix it.
Look at your profiles, it will be marked as taken down.
All my current profiles are active and none has a mark that it is taken down.
Hmm, maybe it was an old one. But then it is even more strange.
A little bit more information would be helpful. ![]()
Open the notifications on makerworld and go to “3D Models”. There should be a report. Click on “view details” to see more.
Thanks,
there it is.
(If a message leads to reducing of points maybe the bell should be red instead of green)
Same information could be displayed at the other place. Just mention.
just a heads up. some of you uploads are missing printed images and they will are required.
They all comply with the guidelines from the short check i made. Printed images are required for the print profiles, not the upload itself iirc.
no, images are required for all up loaded models.
Says it where
no, only the Profiles, but if you put up ONE profile, you need the image. And only junk models don’t have a picture of a printed model. Use the same one as the initial profile.
