I had this problem as well, I got it fixed with switch from print by object to print by layer. There seems to be some coincidence. Try to change that and see if it changes anything.
I am actually not comfortable dupliating entire print profiles (I don’t even think I use print by object) for an obvious bug. This doubles maintenance effort on my side for no obvious reason.
It should either be fixed or it should be declared before publishing those models that this is a limitation. Either way is fine, but clarity is important imho.
When that happens for me, it is usually something to do with
the purge tower being put in the wrong place
OR
limitations on part height when the print order is by part instead of by layer.
To fix the purge tower problem, I try setting the printer used in the print profile to the one with the smallest compatible build plate.I t seems to handle automatically repositioning the purge tower on larger plates better than if it has to reposition it on a smaller plate.
There is no reason by which having a profile with mixed printing sequences plates (by object and by layer) should be compatible with some of the printers and not with others
If there is a reason it is not clearly stated: selecting other printers in the Edit Profile page should be disabled (grayed out) with a clear message saying why. It is absurd that you can select the printers but then they don’t show up after published.
With my latest models I’ve decided that I’m not going to try to work around all the incompatibles to make it easier for the user to print. As long as it fits on the print bed, I’m going to create a single A1 mini 3MF file with a plate for each group of same colored parts. Instead of them printing everything in one go, they’ll just have to print each bed individually. Much easier for me to manage.
