Printer issue just started
Heat the nozzle to temp and with the teflon tube remove check if you can hold the filament while extruding.
You clearly loose the extrusion more and more and I suspect a heat issue.
If the extruder motor isn’t struggling it might be worth to check for build up on the transport wheels and whether or not some teflon tubing is worn out.
