I just found a bunch of photos that may be germane to this topic.
A few months ago, I posted something here in response to a question about speed optimization. I canât find that post, but I just found the pictures.
Let me explain what we are looking at. This is not a CAD-generated file. Instead, it is a cube primitive that is 1mm tall. I set the top and bottom levels to zero and used the grid infill.
So, what exactly does this show? An imported file, whether STL, OBJ, STEP, etc., is always converted to a mesh. Thatâs how slicers work. However, if the slicer calculates geometries, it will be as precise as the X-Y nozzle movement for that printer allows.
In this example, you can see the limitations of a grid laid down as infill. This demonstrates the limits of mechanical movements. Even with the absolute âbestâ nozzle movements and calibration, the results, though uniform, also show uniform displacement. I found no way to remedy this.
Here is the sample grid at scale. If memory serves, this was a 75x75x1mm cube primitive.
Here are some zoomed in versions
This side is actually an example printed on a specular(mirror like) build plate that I use when printing optically clear models. This was printed at very slow speeds but you can see how the filament achieved a glass-like smoothness where it was in contact with the plate. I believe this further illustrates what the limits of a 0.04 nozzle can get to because in this case, the layers were laid down at 0.28 layer height which meant now âsquishingâ. Again, you can see that these columns on the left are very uniform but the intermediate lines, although uniform, still show start and stop extrusion that canât be avoided.
Here it is under extreme magnification backlit. Note that the grid was uniform in that one can see the alternating shapes but far from the square grid pattern I wanted.
And as you can see here, there were random locations that had some blockage in the grid. This was a precisely calibrated filament too, or at least as far as my skills could get it.
If you click on this zoomed in photo, you can see that the grid pattern is at the 1mm resolution which it appears you were trying to achieve.
