sometimes on mine projet, i found
printing by right nozzle give less time at
left nozzle!!
sometimes give me 1 hour on 4,
for model on 1 color!!
WHY?
i know right nozzle accept TPU and CF-GL, but 2 is same i believe
please post in a language that you’re familiar with so that we can use a translator to read it, or let chatgpt translate it for you
If I understand you correctly, you’re getting different print times depending on which nozzle is used. That can happen. The nozzles don’t move in exactly the same way, and the slicer may choose different paths depending on which one is active. Their physical position also matters — one nozzle simply has a shorter or longer way to travel. The placement of the model on the build plate can make the difference even bigger.
In short, even if the nozzles look identical, the positioning and movement can still lead to different print times.
