The X2D has a switch inside the machine that has hot and cold on it. Are these selections available in Bmabu Handy? This is where I have been starting most of my prints
For whatever reason, it won’t let me post the file. It’s coming up with an error stating the maximum file size is 500 MB. The file is only 26 MB, so no ides why it won’t let me post it…
There is no switch on X2D, thats an indicator and should not be adjusted manually.
Yes you can use the handy to adjust the chamber fan. However the AUX fan needs to be turned off in the filament profiles before slicing on a computer because even if you turn it off manually during a print, as soon as the filament switches to another color it will be turned on automatically again.
I would highly recommend you spend a bit of time and read the bambu wiki to familiarize yourself with all the fans, adjustment, features etc of the printer and software.
I have never changed it. I just assumed it was a switch because that’s what it looks like. Anyway, that printer is just sitting in the corner now I have my H3C. I will have a proper of the Wiki when I get the chance. I have been going through Bambu Academy, which should also cover some of this?
Yes that’s correct. Save the file just how you would have it for your slice. Upload the 3MF here. This way we are seeing exactly what you have.
Sukotto85
I’ve only been in the hobby for around 6 weeks
This is a lot of printer for only having 6 weeks of experience. No worries, we all started at some point. FYI, it is an addiction. The more information we have the more we can try and help. I’m still learning after 10 years (just under) of 3D printing. There are some really smart people on this site.
Here is that 3mf with the AUX fans turned off. I was not sure which PLA you are using so I changed it to Generic PLA. It might slow down the printing speed a bit (due to lower max flow rate) but thats not a bad idea to avoid your print failure. You will still need to manually turn off the chamber fan after the print starts.
If you are having problems with the temperature dropping, and do not want to heat the building, can you put a insulation cube around the machine?
That’s what my partner said. Just not in those words.. Given the file size, I’ll have to load the file on to another file and link it on here? It is very additive. It’s a hobby that can support a lot of other hobbies
Thanks! I’m using mostly Bambu Lab filmanet for the print, but I am using a couple of generic ones. Is it a bad idea to select Bambu, even if you using generic filament? That’s what I have been doing, mainly based on a few YouTube channel suggestion
I’m not too precious about heating the room. Thanks for the suggestion, though
