I’ve noticed that when Bridging, on any particular layer, when the bridge is started, the slicer will complete the outside wall, then, continue working the rest of the layer walls, before it comes back to complete the bridge…. This causes a weak unevenness to the bridge if there is a-lot of other layer work. It also leads to sagging, as the outer bridge wall, has lots of time to sit there, sway, and cool, and then string.
Is there a setting that forces the slicer to prioritize bridging, (Outer wall, then the rest of the bridge, then the rest of the layer?
I realize that this is a global slice issue, not just Bambu.
Thank and regards.
