Prob importing QR code to Studio
File is attached, it wont let me attach the SVG for the QR code. No matter what I do the QR code comes in as a block, not a QR code.
Trying to get this done for an event I have this weekend for my business.
Table QR sign.3mf (38.1 KB)
Can’t tell what’s going on from the project file, but here’s a tip. 3MF files are simply standard ZIP archives, and you can add whatever you want to them like any other zip file. To open it / add files you can rename it with a .zip extension then use system tools to add files, then rename back to .3mf extension. Or use an archive utility that doesn’t care about file extensions, like 7-Zip.
And “vote” here: Please allow more forum post attachment file types :wink:
-Max
Im so new on here, I dont see where to vote on your other post.
So I downloaded an SVQ QR code. I did “Compound Path/Make” in illustrator, and then add part”Modifier” in studio, and it brings it in as a shape but the actual QR code isn’t there, just a 3D box the size of the QR code.
I do this with logos and text for keychains, no problem. but the QR code, just wont work.
I meant so you can attach the other files here, to test with. There’s no way to actually vote for a suggestion, sorry, I just meant support it somehow.
Why compound path? That probably makes it look like one object to Studio. Pretty sure it needs separate path objects, but not sure. If the QR code is already an SVG, why do anything with it at all (in Illustrator)? I’m not sure what you’re downloading, or why it would be different from what you usually do, sorry.
-Max
So this is what I get when I bring in the QR code SVG the way it was downloaded with no modification.
