[Problem] no extrusion in the middle of print
Yes, next step: Orca slicer (I was waiting no beta versión: Release OrcaSlicer V1.6.3 beta · SoftFever/OrcaSlicer · GitHub)
I am also waiting for information from the manufacturer, its printing profile is a General ASA copy, nor does it match its product specification sheet
I use the beta 1.6.3 I found a few bugs but they have been fixed also they will keep updating it anyways.
Go ahead and test it out plus it has more settings :grinning:
Filament makers will give you general settings as a guideline but every printer will have its own ideal settings you have to find them.
v1.7.1.62 Releases · bambulab/BambuStudio (github.com) :grinning:
Hi, I’m having exactly same issue with clogging nozzle with exactly same model (silica gel box?). So I have to do cold pull tommorow and will see. The model (many retractions as mentioned above) must be the issue… I printed whole new Hydra without a problem.
Any recommendations if I can’t even get the temp tower to print? :frowning: after layer 10 ish it stops printing and just ghosts. With some stringing.
Thanks in advance x
Same problem here with brand new Bambu ASA orange: Clogged nozzle.
Cold pull does not help very much. I could remove only small portions. After hours of trying I used a 2mm drill bit whiched worked for me very well.
I retried and failed again in the middle of the print.
The third try with slightly open front door also failed.
Try calibrate on new Bambu Studio version…
@mainmind Did you get this problem fixed? I have the same problem with the extrusion stopping after 30mins. Cleaned and replaced extrusion gears. Multiple heads.
In my case, the manufacturer sent me another spool of filament and I had no problem again creating a custom printing profile…
