I am attaching the clock components to a clock I already printed. The washer and nut go on with no problem. When it comes time to add the clock hands, I can’t figure out how the hour hand (the shortest) stays steady. I attached a picture as that will hopefully make things clearer. Do the watch hands slide all the way down next to the nut? I don’t want to force things until I know a bit more. Thanks.
It should be press fit, the hole of the hand should slide into the matching diameter of the clock’s spindles. Repeat for each decreasing size hand.
A model would normally come with a printable set of hands to attach rather than the supplied one from the kit that likely do not match the design of the clock.
