Problem with Filament Manager at Bambu Lab Studio
I have still the problem. With last update this topic is not solved for me.
Hello,
I have some similar issue with the filament manager in the Bambu Lab Studio application. Some spools seems to be up to date, some not at all. The process and the synchronization is not regular. The estimation is too not very precise.
I hope that we will have an update with a better filament manager : it is quite easy to manage exactly the weight of the filament as the slice know the comsumption of each filament.
I have the issue where it WILL work for my SUNLU PLA Basic spool, where it updates it and recognises it being in the AMS, but not for my SUNLU PETG Basic, I tried like 20+ times adding in the custom filament, read from AMS, add manually, but it will not add the green dot over the PETG indicating its in the ams, so for a test i swapped it to be a spool of PLA and it worked instantly showing up as active in my AMS slot.. So for me I think currently SUNLU PETG is bugged in the Filament Manager
(to add to that, my frustration lies with the fact that if you choose ‘‘Read From AMS’’ you’d THINK it would understand that that spool is currently IN the ams… but I guess ‘‘making sense’’ isn’t applied here.
I have the same Problem with Elegoo filament. The software has regarding this a big bug!
I also have a problem with weight estimation.
I was stumbling about this post because I tried to set up my Filament Manager.
Is it correct, that I can’t use Flow Rate calibrated profiles for Filament Manager profiles?
They’re shown as unsupported, same as third party filaments, connected to BambuLab profiles.
If so, whats the point of either calibrating or using the manager at all?
Or is there a solution for this?
Example:
I created a new Filament brand, Elegoo, because it’s not listed by default.
I connected it to PLA, set Matte as parameter.
Then I selected P1S (as it is my printer) and 0.4mm nozzle, which is the nozzle I use.
When I try to bind an AMS slot to this filament, it says, it’s unsupported.
Oh, and when using a BambuLab PLA Matte preset I calibrated using the calibration tools inside Bambu Studio, it’s also shown as unsupported.
Hi, sorry for my late respone. Right now there is no solution. I have at my filament manager some added filaments, where the weight update doesn’t work. Sometimes it works, sometimes not. I have also started a support ticket regarding this topic. Till now i have only got the message to wait for any updates which solves the problem…
