Problem with my filament feeder H2S
I think I have a pproblem with my filament feeder. I’m attaching a video that will illustrate it better than words can. Thank you for your help.
This is probably not an AMS problem, but rather the length of the PTFE tube between the buffer and the head. When the head operates near the front doors, the tube bends too much. I extended the tube by a few centimeters.
I have a question about your buffer… it also has H2S, but I don’t have that middle pipe… ??
The middle one is the air inlet for the laser system, non laser units doesn’t have that one.
Ah, that explains the difference. I kind of forgot that H2S also comes in a laser version.
As for the behavior of the buffer, it’s most likely the length of the tube… you need to adjust the length so that there’s enough at the door and in the lower left corner.
Merci pour vos réponses :slight_smile:
