Problems with EasyFil ePETG print
When slicing a print, I get this message:
The filament is EasyFil ePETG and I have choosen Generic PETG as filament and the 0.20mm Standard @BBL H2D profile
The result:
I suspect the profile settings has to be changed?
Best regards Tue.
  1. that warning is because of those floating tabs on the top, enable supports
  2. Whatever filament caused this string factory needs to first be dried for at least 12 hours, and then after that you may also want to do a flow Rate calibration on that filament.
I agree with the reply above. Lots of stringing and changing line sizes, dry your PETG. Only thing I can find about profiles is that the ePETG wants the range of 235-275°C while the generic profile has the range of 220-270°C. It set’s the nozzle temp to 255°C anyways which is well within range.
If these problems persist I’d suggest lowering speeds and playing around with the temperature.
