Problems with unloading filament
Hi,
It seems something went wrong when I tried to unload the filament in one of the slots (#3 probably doesn’t matter here). I was using a SANMATE TEMP Color Change filament 1kg original spool (not re-spooled to Bambulab) and it got stuck during the unloading process. I had to disconnect the AMS unit, bowden tubing, cables etc. and then pull the filament out by force, not cool. Is there perhaps a weight limit for the AMS transport mechanism and what is it? It certainly seems to have problems with a 1kg loaded spool. So what is the weight limit? 0.5kg?
Best Regards
