Pros and Cons of Infill Patterns
I had been using grid since that was the default and default on my old printer but recently tried gyroid and I think it’s a huge improvement. I hadn’t realized the bit about the nozzle whacking existing filament and making bumps where the lines cross.
Gyroid might not be strongest depending on orientation but it prints smooth and the extruder just sashays back and forth. The printer is much quieter in those sections.
Such a small but big thing. I hadn’t paid much attention to infill types except in seeing the strength of grid and triangle. Good to know gyroid isn’t shabby either. Thanks for the discussion here!
3D honeycomb with low infill % is great for saving filament when printing larger models.
gyroid in fill is best for multi directional stress/forces, 3d honeycomb is good for single direction forces, especially x/y, cross hatch is kinda weak, cubic is also pretty good for multi directional forces
New to printing and trying to research options for infill.
I read through the article, and then saw this. Wouldn’t Cubic be the preferred option over Gyroid as they have the same Perpendicular Failure Load (260KG) while Cubic has an even higher 270KG Transverse Failure Load vs Gyroid’s 260KG? Is there a downside to Cubic that I may be missing?
Thank you!
Some may have other considerations but some infill patterns create cells/volumes in a print that limit internal flows to a particular direction. Honeycomb is an example. X-y is blocked but z is a tube. Fill like gyroid is essentially open for flows in any direction.
Cubic is a crossing infill, meaning infill lines in two or more directions get applied on the same layer. So the nozzle collides with lines that have been laid down already. Crossing infills are stronger but there potential printing issues.
  • blobs of material can accumulate, causing defects to top layers going over the blobs on the infill.
  • vibration and inconsistent extrusion caused by the nozzle collisions can cause wall defects.
  • can make it more likely to lose adhesion from the bed from the nozzle colliding with it.
These problem aren’t guaranteed, they just become more likely. I usually use non-crossing, but have used low percentage cubic for its insulative properties.
Crossing infills are stronger because of the extra material at the infill joints, so may be desired to maximize the strength of the part. I haven’t needed it for that purpose yet, but would consider it if a part needed more strength.
To increase strength, I usually use modifiers within the part. Using the mods within the infill, I either make some solid sections or higher percentage infill sections to add the strength where needed
It took me a while to use modifiers but I should have used them much sooner. They are easy to use and work great!
