i have a what i think is a problem with my new Bambu lab A1 mini printer
the ptfe tube and the x axis cable are sagging in the front and idk why this is how it came in the box can anyone tell me how to fix it ive tried all the supports none work and if i cant fix it can anyone tell me if its harmful? to my printer ???
They are wires, they will always sag a little bit. But good thing is there are a million things that you can print if you don’t like that.
Its not really a problem, but it is easily fixable with some simple prints
no like the ptfe rune didint come straight from the box i tried those prints and i have cable clips and it is almost the same
and it says a lot more when the print head is moved right
Respectfully. It is flexible. Use clips to put it into the position you want it to be in.
You might need more than 3. And something that is tighter together
how does that work did your printers ptfe tube also come bent and where it bends you put more clips?
like the ptfe tube are bend in 2 places
and what clip model do you recomend?
It is flexible for a reason. If there is a significant bend and it will not go back, you might just need to replace the tube.
But from the pictures shown, there is nothing seriously wrong with the printer. Try printing some of the clips that I linked and put them on. Print 8 of them. Try the cable spring too. If you are still having problems after that, post some pictures.
Just to clarify, are the cables sagging down and getting in the way or is this just an ascetics thing?
why cant i make a new post i cant find the button?
