Purge tower H2D bed location limitation
Can’t place Purge tower in “one nozzle zone”
I’ve always been frustrated with the 15mm purge tower location limit. But now I’m getting frustrated cause even if you are using one nozzle of the H2D, you are limited to 15mm from the “one nozzle zone” edge.
For instance if I’m only using one nozzle, I can place the model inside the left or right side accordingly. But I still can’t place the purge tower in that zone. Limiting me for no reason.
On top of that it makes it 15mm from the edge of that zone.
At a minimum, the 15mm edge shouldn’t apply to the edge of “one nozzle zone”
Edit:I am able to move the purge tower to the edge of the “single nozzle zone” after slicing, but I still can’t move it into the zone. This is a possible task for the slicer and mechanics if they allowed.
