- Detailed description of the problem
- Printer model used
- Slicer settings used
- Type of filament used
- Photos that clearly show the problem
- .3mf file (if the file can be shared)
- Any potentially useful information that is related to the problem
When purging at a filament change, my purge wiper has begun flinging the poops towards the printer, instead of dropping them away from it. I’ve reduced the purge volume very significantly, checked the purge wiper, replaced the purge wiper with a new one, followed all the suggested adjustments in the Bambu wiki, and it’s still doing it. The wiper blade mechanism operates smoothly, and is fully engaged, so the shim I’ve seen some people use wouldn’t fix this issue.
I read some mention of putting PTFE on the wiper blade, so I put a little 5mm piece in the gap for the nozzle, and the purged filament still falls to the inside, but doesn’t fling as far, and it sticks to the nozzle less frequently, so it isn’t landing on the print plate (or being dragged there) as often. But it is still sliding under the bed, and I’ve found poops in the track beneath, so it’s still very concerning.
I’m using an A1, with AMS Lite, Sunlu Silk PLA and Bambu matte PLA.
I can’t figure out why the nozzle isn’t centered over the purge wiper – it seems like that extra 5mm or so might make a difference, but everything is in its designed position, so far as I can tell.
