Purify air at print end
That’s a nice option to reduce fumes after printing. I know it won’t perfectly clean the air, but it’s still something.
What do I don’t want is the printer to always do this. I want to manually trigger clean cycle. I can’t find this in the menus. Is there such thing? Or can I just run the "right(filter) fan” manually?
Does someone know how much air purifying cycle takes? How long should I run the cleaning fan for optimal time/effect ratio.
You can edit the machine end gcode to remove the option I think. Can’t remember the exact line offhand but I recall it runs for 3 minutes so find something that ends with 180
The option can be turned off in settings. That’s not my problem. What I asked is if that option can be manually triggered after the print - when you know you printed a nasty filament.
Having that option when printing with pla makes no sense because the air is vented to outside without the filter anyway, so it doesn’t help at all.
Well thanks. I’ll run that manually for 3 minutes or so when I need it. It would be nice if bambu added manual trigger for this option
Ah I’m sorry, I misread it. You can just insert that line from the slicer in Notepad or something. Then save the file as a gcode file and upload it to your USB drive. Run that file and it will “print” for 180s but the only thing it does is to run the purify air command.
