Hi,
Brand new to 3D printing, so apologies if this has already been answered.
I kicked off a large print last night that will take several days to complete. The project uses 2 colors --black and white filament. I have an AMS 2 connected to my printer with the following spools loaded: 1. white, 2. black, 3. red (not needed for the project), and 4. white.
I’m about 18 hours into my print, and the printer has been pulling filament from spools 1 (white) and 2 (black). So far so good. As far as I can tell, when spool 1 (white) runs out, the printer will automatically switch over to spool 4 (also white, same brand/type).
The single black spool (spool 2) should theoretically suffice, but I was wondering if I could remove spool 3 (red and not needed for the project) mid-print and replace it with a second black spool.
Is that possible? Would I need to pause the print to do that? Can I simply press the oval tab and manually unload the red mid-print (it’s not in use at all), drop in a second black spool, feed in the filament, and configure the printer to auto refill spool 2 (black) with the newly loaded spool 3 (also black)?
Any advice would be appreciated! Thanks.
