Quick Help-Switching Filament mid-print
Quick Help-Switching Filament with AMs mid-print (spool ran out)- how do u do it? The other reel is the same color in another slot. Do I have to manually change?
Thanks
That is usually the quickest solution in a pinch. Switch the roll over and hit resume.
For auto-refill to work, it needs to be enabled and both spools configured identically.
Thanks much. Will do it that way.
What @EnoTheThracian said.
My only contribution is…
We have all been there.
As he said, look at the auto-refill option and see how that can help when you have the ability to benefit. You need a spare slot in the AMS, have it configured and know it will be required.
If not, do not worry, the swap out is easy mid-print.
