I am going to start this with being clear that I didn’t actually rate the model in question.
I may have what might prove to be a bad habit. I often will simply delete what is on the build plate in my slicer and replace it with a new model. In this particular case I had downloaded a model from MakeWorld and decided I wanted to make a bit of a modification to it. About an hour later I decided it was instead going to be easier to build my part myself and so eventually I deleted the downloaded model from the build plate and dumped my model on instead. After completing the print I notice that Bambu Studio (and MakerWorld when I check the website) is requesting that I rate the print.
It seems like a easy to exploit “bug” if I can download a huge print and replace it with a tiny print (as was my case here by the way) and still be able to add a rating. As I said at the top, I didn’t rate this model. I didn’t actually print it, so it would not be an honest rating and besides I didn’t feel like finding out the hard way that Bambu really can see if I “cheated”.
So does MakerWorld do anything to check to make sure I printed what I downloaded?
