I know that probably no one here can help me much (but I need to just “vent”). And … maybe … someone “in charge” will read this after all (?)
I’ve come across a requirement that models on MW must have at least one real photo. OK, I understand the reasons why this is the case and I fully agree. However, the requirement for a real photo also applies to Print Profiles added by Designer, and there, at least in some cases, the requirement is nonsensical… even (sorry) stupid…
Example (and really just an example) - I need a pipe stand/rack, so I design one. I come up with an excellent solution for attaching the pipe to the rack, which I like so much that I want to offer it to others. Of course, I will have a lot of REAL photos for the main model… simply because I want to show off how great it is.
But… my model… which I developed for my specific needs… has two floors, each for five pipes. I have ten of them, so I don’t need any more and two floor solution fits great on my own bookshelf.
But, I want to offer the model to as many people as possible and meet their various requirements in advance. What might they want? So I’ll make more versions, which I’ll publish as separate Print Profiles… a model with only one floor, two floors, three floors, and a MAXI version with four floors… and each of them has several sub-variants - for 5 pipes, 10, 15, 20… I should point out that it’s all still the same… the main ingenious mounting solution (which is why I’m publishing it), is still the same… it only differs in the number of floors and the number of slots on each floor. Are these models functional? Of course they are… it’s all the same… there can be no doubt about their functionality… it only differs in size.
However, in order to publish individual versions as separate Print Profiles on MW, I need their real photos! So what now? Should I really print all versions?? if I’m not mistaken, there are 16 of them… and some of them are pretty large … what am I going to do with them? I don’t need them! One stand that I developed is enough for me, and maybe I’ll keep one more… but I really don’t need 16! It will take me a week or two to print them. And once I print them and take one photo, what next ? Will I throw them away into garbage? How many kilograms of filament would be printed unnecessarily just to accomplish a request for a real photo ??
Let me repeat that I understand why a real photo is usually required, but in cases such as the one described, it seems completely nonsensical to me. How do you deal with this?
P.S. An identical situation occurs when the Print Profile contains the same model as the main one, but a different material is used (the profile contains the recommended settings and parameters). Do I have to print the model again in a different color to get a request for a real photo?
If you read it, thanks for your time and appreciate your opinion/advise how to solve this …
TW
