So I noticed the TPU HF settings are now available in the latest beta. And guess what … the only change is the maximum volumetric speed
I diff’d the JSON filament profiles just to be sure:
> jsondiff Bambu\ TPU\ 95A\ \@base.json Bambu\ TPU\ 95A\ HF\ \@base.json | jq
"op": "add",
"path": "/filament_max_volumetric_speed",
"value": [
"12"
"op": "replace",
"path": "/filament_id",
"value": "GFU00"
"op": "replace",
"path": "/name",
"value": "Bambu TPU 95A HF @base"
Currently doing a test print after drying overnight for 8+ hours. Last time I do admit I was a bit skimpy on the drying. My experience has been that I can get away with a four hour dry straight out of the silver bag – apparently not so this time! That first print came out looking like a total booger.
Here’s an interesting observation, before I could even get a print even starting to work: I had a ton of trouble getting the extruder to take a good grip on the filament! I ended up cleaning the 0.4mm nozzle with several cold pulls to make sure that was free of debris, then manually extruding and feeding the filament by hand until I could let go and see the extruder able to pull the spool by itself. It seriously took half a dozen tries. I have not experienced that with TPU on the X1C. It could be a foible of TPU on the A1M? Thought I would mention it in case anyone else struggles.
Pictures of the HF result forthcoming now that I have filament being laid down.
