I need to move my A1 into a better ventilated room to print some TPU. I know i can undo an individual tube from the AMS and thread in the TPU but I need to remove the whole AMS to be able to transport it. How do i remove the 4 into 1 part from the print-head?
You don’t, stop!
You remove four PTFE tubes attached to it.
When you installed it, you inserted the PTFE tubes into the mounted 4-in-1 adapter.
While that can be removed, it should only be done for maintenance as there is a tiny thin ribbon cable that can easily break.
You said you have removed one PTFE tube before, just do four.
OK thanks. I imagined the 4 into 1 was part of the AMS
Malc’s not wrong the best option is to remove the PTFE tubes. If you do need to remove the AMS Lite Hub this tool will help. I didn’t design it but it’s one of the few tools I’ve downloaded for my printers that works very well. It also helps you remove the hub without removing the part attached to the ribbon cable.
Amazing A1 and A1 Mini AMS Hub Tool by LayerLux3D MakerWorld: Download Free 3D Models
