I have bought some replacement hot ends for my P1P and they come with two spanners and a number of nozzles. { despite what 99% of youtube says a nozzle is a small thing with a hole in it, not a big lump of heat sink adorned with wires}.
the nozzles have a hex shape exterior which fits one one spanners and the other spanner fits the hot end. Now try as I may I just can not get the two things to screw apart. Am I just being a wimp and must apply even more torque { which I don’t think my puny hads can do!) or have I missed some thing.
It would seem it’s just a screw thread but its got me beat!
If the nozzles screw in, it is not a Bambu hot end.
Bambu (OEM) nozzles for the X1 and P1 series are pressed into the heat sink and are a unit. The nozzle does not unscrew, and if separated from the heat sink, the nozzle cannot be reliably re-inserted.
And to add to that, In my opinion, uniting nozzle, heatbreak and heatsink in a single unit was a smart design choice by BambuLab, eliminating many shortcomings of screw-in nozzles and is one key aspect for achieving the current performance and reliability.
If you look elsewhere, E3D did a very similar thing with the Revo nozzle system. Prusa has a similar approach with the Nextruder system.
They both didn’t integrate the heatsink, but the key is integration of nozzle, heatbreak and cold side in a single unit without seams and gaps.
I think, Ultimaker was the first to integrate all critical hotend components with print cores for the Ultimaker 3.
All those companies took that step for a good reason. screw-in nozzles simply are technically inferior regarding performance and especially reliability.
If you want to go back, feel free. I have been using the same nozzle for > 1000 hours, so I really don’t feel like accepting the drawbacks to save 13 bucks for replacing a worn nozzle. I have added a 0,2mm and 0,6mm complete hotend for easy swapping, which really vanishes in cost compared to the other consumables.
When nozzles were made from pure brass, swapping was a regular maintenance operation. With more resistant materials, this just isn’t necessary very often anymore.
