Request - Parametric model (Customize) - Import Print Profile
When using the CUSTOMIZE function (parametric model generation from Fusion), I encountered an unpleasant limitation (problem) – insufficient options for setting the print profile. If I am not mistaken, currently only a few parameters can be set, such as generator type (Arachne/classic), number of walls, infill type, etc.
BUT… it is definitely not possible to set everything that is necessary – for example, it is not possible to set the filament type, print speed, and others (for illustration, I have a model that requires PETG and a low print speed), but the generator automatically adds PLA and sets standard/default high print speed, which is “totally off” for the given model. Similarly, many other parameters that may be key to successful printing are unavailable.
The user then has only two options - either print the model as generated (which is wrong), or manually import the print profile (from the main one) themselves… which is also not good, because it is inconvenient work, and moreover, for some users, beyond their capabilities.
Proposal: I think it would be better to solve the parameter settings differently - by importing from the Main Print Profile of the model → in addition to the Customize function, the model will contain one (main) normal print profile in which designer can set everything as needed. And the generator will import these settings “from A to Z”… it will only add new generated STL to the created 3MF. This would ensure that the generated model has everything necessary for successful printing according to the author’s requirements/ideas.
TW
P.S. I’m not sure if this thread is “the right place for such a request” in this forum (haven’t found better place). If not, I apologize… and thank in advance to the administrator for moving it to the appropriate section…
It seems to me that’s the right place to post such request :head_shaking_vertically:
the minimum imho is to allow a change of material, with a warning so beginners can know there might be a risk if they don’t know what to change, but more advanced users can find their way
I thought it was just me. Spent quite a while trying to figure out why the maker’s profile settings weren’t accompanying a file after using “Customize”. I guess the work around is to copy over the setting from the uncustomized file. But yes, that’s obviously not going to be practical in the long run.
