When you change the interface material to a different material, you are prompted with suggested changes:
After I said ok, I went back to default, which caused me to not put those other settings back, and ended up with supports fused to the print. I suggest that when switching from an interface material back to default, the same prompt should pop up suggesting adjustments to the same settings.
