hi everyone,
I have a problem with low resolution on my stl. Is there anything i can do in the slicer or another programm to get this round like it should be.
I use Fusion to draw things up and it’s a “refinement” setting in Fusion in the stl export process that causes those facets for me.
I just set refinement to high and then when I import into Studio I get much smoother surfaces.
I bought it via cgtrader, so i cant set this… i would need a possibility to get this done afterwards
If it is an stl file, with no flaws, then in cad, remove the outer wall, and replace with a cylinder with higher resolution. The inside walls look to be tapered which would be more difficult, but perfectly do-able, but may not be worth the effort.
