I have quite a large project, sliced for the A1.
Calculated print time for the A1: 28 hours.
Now I change the target printer from A1 to H2S. Everything else remains the same.
Calculated print time for the H2S: 46 hours.
I would have expected more or less the same print time, since I have restricted the speeds and accelerations and both printers, but to the same values.
Both printers are configured with an 0.4 mm nozzle.
I’m using the Bambu Studio 2.4.0.70.
It has nothing to do with my settings. I took half a spool (filament spools from Makerworld) and sliced it with the default settings of both printers unchanged. Here, too, the H2S takes longer (3:50 hours) than the A1 (3:30 hours).
If you compare the values from Printer Settings / Motion ability, the H2S should be faster. I think there is something wrong with the Bambu Studio.
