Send file via Bambustudio
Hello everyone,
I have a question, I can’t find a solution, I have already tried various things.
I can no longer send files to the printer from Bambustudio.
I have the printer in the network normally and in the cloud (not Lan Only). But when I send files I always get the error message. In the past, it worked great to send the next files after printing.
Does anyone have any ideas for solving the problem?
Greetings
Shamen
Are you 100% sure both printer and bambustudio are logged in with the same acount?
Thank you for your answer.
Yes, the printer is connected to the same account. I have also reconnected it. Sending the print directly works. But only the file send comes the message from above.
The Bambu cloud was down earlier today, so that might have caused your problem in cloud mode. I believe that issue has been corrected.
I do not think 00000000 (as shown in your image) is a valid LAN access code. Tap the circular arrow for a new code.
I don’t often use “Send”, but I don’t think it can be be used in LAN mode. I think this may be related to the fact that Studio cannot access the SDcard in LAN mode.
I get this message even though there is a card in place.
FTP file transfer does work in LAN mode, so you might try using “Export Plate Sliced file” to save the g-code to your printer and then copying it to the SDcard via FTP.
