So I’ve run into this three times recently. If you pick a file to reprint directly from the screen on the machine it does not check that the nozzle is compatible. Twice now I’ve hit reprint on a file that is setup for a 0.4 nozzle forgetting that I have the 0.2 installed. And it just tries to print it. The result is a stringy mess or constant stops due to “filament being tangled”.
It’s my fault for not checking the nozzle, but why doesn’t the printer warn you like it does if you try to print something with the wrong nozzle from the slicer?
Yeah I swap nozzles a lot and I forget which one is in there. When I print from the computer it warns me, but if I print from the screen it does not. I don’t realize what is going on until I check on the print and notice it’s printing weird.
I’m just selecting things I previously printed from the interface. I have a few prints I do a lot so they’re always still on the card. I use the app and cloud for most things, and it warns me before allowing me to print with the wrong nozzle.
The weird part is I have been doing this for years but for some reason have only run into this 3 times in the last month or so. I’m not sure if it use to remind me or if it’s always been this way and I just got lucky that I didn’t do this before.
Spit balling here, since I use different slicers of different vintages, so I might be mixing things. Print file names contain material type & nozzle size. If the file name changes, deleting this info, it might be a problem. If I mix my A1 with my mini sd cards, things won’t print. Since neither printer has a nozzle choice in their settings, mismatched nozzles will still print, creating a problem if the nozzle is smaller than the programmed size. Heavily wears on extruder parts.
