I’m having trouble setting the order for things on the R1. I need to cut a hole in a shape and THEN cut the shape out but no matter what I do, like setting the order of the lines, does it in the right order.
It always cuts out my shape, the shape falls to the bottom of the R1 and then it tries to cut the hole in it.
Check out the screen shots I made below. Make sure to apply a color to each layer or process order that is different. Change the order at the bottom of the MAKE screen. Then go to prepare and adjust the settings for the material batch to be by layer color and not automatic. The order on the right is just for viewing while you design the item. The order on the BOTTOM is the order it will use to make the item.
Thanks. That is strange but it does make a little sense. I also found another way to do it. I grouped all my cuts together in the right order and then merged the cuts. But I can see how that can make things messy if you are dealing with a lot of individual object.
Im used to my other software and it took me a while to figure it out on Bambu Suite. If you do it this way it makes things really easy even when you are bringing multiple saved files into the same project. If you open up both projects you can copy items from one project to the other and everything will engrave/cut in the proper order. DO NOT use import. Import will not import any of the settings from the file, it will just import the shapes and ask for the type (IE Laser, Cut, etc) and then anything for laser comes in as a laser line. We use our C02 machine for a lot of Engraved labels and we use Laser Line, Laser Fill, and cut. If you copy and paste from 2 projects it keeps the type of operation and color order correct.
I keep my color coding the same between files
BLUE - Engrave
Purple - Cut Holes
Red - Cut Out Part
I can Copy/Paste multiple labels from different projects (NOT IMPORT), and just place them on the sheet and click prepare. It will engrave all the text from all the different files (laser line or laser fill), cut out all the small holes, and then cut out the part.
Note: I’ve only been testing this with the H2D as we still use our other brand C02 laser for the shop. I’m waiting on the R1 but this has allowed me to figure out if the R1 and Bambu Suite would suit our needs.
One other tip that helped me out that i didn’t see in anyone’s tutorial. If you go to the prepare tab first. Capture an image. You can now go back to the Make/Design workspace. Right click on the background and select “Show captured Image” and the picture of your plate will now be in the background of your design workspace.
