Right, I wasn’t referring to Orca Slicer, I was more trying to point out how ridiculous claims are being made by people who have never used LAN/DEV mode.
Sadly I can’t use Orca Slicer right now because I added Filament Track Switch and 2nd AMS to the X2D, due to pending support, Orca does not see either AMS, thus I can’t use it directly. The only way is to manually add the filaments/profiles in orca, slice, export and use Bambu Connect to assign, but that has it’s own issues with track switch equipped x2D.
So switched to Bambu Studio in mean time (still in LAN mode) and it is so bad. Because of this, I also have to rely on Bambu’s system of handling PA values.
Regarding the profiles, I was referring to the custom filament profiles themselves. I use lot of non Bambu filament and I create a profile for it. Say I make a profile for iSANMATE Matte PLA and I save it, when I go and load the filament in the AMS, I can go on screen to assign filament for that slot, because the custom profile gets sent to the printer via cloud (and only cloud), iSANMATE would now show up as one of the choices under Brand, and depending on what material profiles you have for that brand, they will also become available in Material section. Selecting this then links this slot/filament to that profile. So when you use the sync function in Bambu Studio, it auto selects the profile for that filament. Which intself is reliant on Bambu Studio being signed into cloud lol… all while the profiles are also stored locally, Studio just doesn’t use them for sync function and force cloud use in this instance as well.
But in order for all this to work, the printer needs to have the profile on it’s storage. You CANNOT manually send or upload the filament profile, which would be definition of what Developer Mode should allow one to do. Nope, that transfer can ONLY happen via cloud, which you can ONLY get using the Network Plugin, which in itself is now in question if it’s a AGPL protected or not…but besides that, there are general features like this they intentionally gated to make the user experience a worse one if they don’t use their Cloud services along with all the other issues I mentioned.
They can’t even be bothered to provide a decent experience when users are using their own freaking official software but in LAN mode, which I’m sure is also why people move to Orca when staying local. Truth is that they want LAN mode option to go away so badly but they also can’t completely get rid of it without bigger backlash, so other option obviously is to make the experience worse or impossible to do some things at all without at least briefly switching to cloud mode.
