I’ve been on the hunt for a proper setup for my H2D since it launched, it was sitting on my work desk for months before I decided on the IKEA BROR cart.
It’s a great thing that can hold 3 AMS and 1 AMS HT at the top. If you need more AMS, you can always use the bottom shelves.
I have mine behind my workstation setup. I built a rack system out of 3030 profile and the lower section houses my Resin printer, which is sealed and the upper part is for my H2D, with my 2 AMS’s on top.
I have 2 HT-AMS units behind the 2 AMS’s and the H2D vents out using the same ventilation system as my Resin printer. Just need more space for filament now!
H2D with AMS 2 Pro and 3 AMS-HTs. Home built roll-out cabinet. I have very tight quarters in my home office, so everything has to fit like it’s on a sailing ship.
Late to the thread. This would work perfectly for me! I need to roll my H2D out of the room about twice a year. Do you find it wobbles a lot with the wheels locked? Technically its over the weight rating but I think that should be fine? I have 2x AMS Pros and 1x AMS HT, so same setup as you.
There is a small amount of movement when printing large prints, that’s all. Even with non-locking casters the cabinet does not move from its position. Wood from Home Depot, nailed and glued.
The four corners are made from 1-1/2" by 1-1/2" lumber (actual size) with a corner routed out so the plywood dovetails into it. Those walls are 3/8" plywood. Top is 1" thick pine and the bottom is 1/2" plywood.
My office is small and every spare inch is precious, so all my tables, benches, and shelves are custom made to fit the room. The cabinet for the H2D is as small as I could make it without stacking the AMS.
Yes, would definitely work fine on a smaller monitor. 65” is a bit excessive, but the monitor (TV) cycles various dashboards, some of which are more information-dense.
Cos I took the print off the plate The dashboard shows the status of the last print.
