Silicone socks P2S vs H2x socks
Need some spare silicone socks for my P2S. But they are sold out :-(. Can I order and use H2x socks. I know the hotend H2x en P2S are the same, but are the silicone socks the same?
https://wiki.bambulab.com/en/p2s/manual/p2s-faq
Q: Can the nozzles of the P2S be used interchangeably with those of the A1 or H2D?
The nozzle is compatible with that of the H2D but not with that of the A1. The hotend silicone socks are not compatible with either.
You can use H2S socks.
I’ve had one of the supplied P2S socks melt and disintegrate in parts so went to order some more to find them out of stock… On my last one now, but I got some H2x socks, and while they fit with a bit of wiggling (wider than the P2S ones) and print fine, there’s an annoying warning that the sock isn’t fitted every time I go to print.
Looks liek the P2S will be available in December, so hopefully I don’t have another mess up on me between now and being able to order some.
H2D socks don’t fit well, and you’ll get errors on the printer, which you can over ride, H2S socks are a much closer fit, so they work better.
Most sellers sell H2S/H2D socks and have no idea there’s a difference, H2D socks have a flat bottom, H2S and P2S have a 3 sided bottom.
does the p2s socks fit the h2d/c ?
