Hi,
I’m trying to calibrate skew on my P2S using the Califlower Mk2 calibration model and calculator:
https://vector3d.shop/pages/califlower-calibration-calculator-mk2
I printed the first Califlower, measured it and calculated the correction values using the calculator. Then I added the following lines to the Machine start G-code in Bambu Studio:
; ======== SKEW ADJUSTMENT ===========
M1005 X99.57 Y99.37
M500
After that I sliced and printed the Califlower again using the same filament and settings.
The result is that the second print has exactly the same skew as the first one. The measurements are identical within measurement error, so it looks like the M1005 command isn’t doing anything on the P2S.
From what I can find, M1005 skew correction worked on the X1C, but I can’t find clear information about whether it’s actually supported on the P2S firmware.
Has anyone successfully applied skew correction on the P2S, or is this command currently unsupported on this machine?
