Slicer Skipping Sequential Sections Then Returning Later For Them
Slicing this, very strangely, it just … skips filling in some sections, only to come back later? Seems inefficient for it to do it this way. I’m not sure what settings I should try changing for this (I’m trying to combat stringing), or even IF I should, maybe it’s doing that for a reason?
OrcaSlicer does a similar thing, although different sections, sometimes multiple skipped in a row, to then come back to finish it before moving to the next layer. Suggests to me this IS intentional on some level but for the life of me, I don’t know why
It’s not intentional it’s just deficiencies of the pathing algorithm. Even on a square the infill path can randomly jump around. You can try enabling “Avoid crossing walls” to try mitigate stringing.
Your answer is in the color visualizer.
White is “Gap infill”
That area is too small to put a wall. But it is big enough to apply gap infill. Modify your gap infill settings; or your wall widths; or your CAD to make those features 0.4mm wider to accomodate a printer to put a second continuous [inner] wall in there…
