I found this on my build plate after a print. Where does it go?
Length including head 7.0mm
Thread outer diameter 1.9mm
Allen head, diameter 3.45mm
I’m hoping this is a clue regarding a problem I’ve been living with for a while and attempted multiple fixes for.
Gah, nevermind, I found it: On the back side of the nozzle heater assembly.
All four of these screws were loose. The borrom-right one is several mm loose, and the two left ones I tightened half a turn.
Are the four spring washers here intended to be the source of elasticity for the eddy current sensor to work?
system
Closed
3
