Speculation on differences between H3C and P3C
Other than the obvious leaks that have come out regarding the P3C such as seven tool heads rather than nine. What do you think the major differences will be between the new H3C and leaked P3C? Obviously the P3C will make some sacrifices for it to be a less expensive option, what do you guys think those sacrifices will be?
Just thinking logically, it should be no 2.85mm support, no multitool support, no active chamber heating, and slower speeds. But as I saw in leaked docs, active chambers should be included, and toolheads shouldn’t be different, so multi-tool also should be supported, I guess. The only things left are 2.85mm support and speeds
When you say multiple toolheads do you mean the ability to use say a 0.4mm and a 0.2mm nozzle in the same print? That’s a software issue and if Bambu Lab figured it out for the H3C it seems like it’d be pretty easy to import it over for P3C users.
Is the type of AMS confirmed?
Half the price, 2/3 the size plate, 3/4 the capability, 1.5x the value.
There were some leaks of the AMS about a week ago.
the suspense is killing me. The H3C is out of my price range, so I hope the P3C can fit my budget
The P3C will definitely not have an actively heated chamber, you can see this in the leaked fcc filings of the open printer.
The AMS will probably not be heated as well.
The toolhead camera and therefore the possibility to use a visionencoder is missing.
And like someone already said, it will have 5 tools standard.
No exhaust filter, no double chamber part cooling.
There will be a lot of sacrifices to fit the price of 1000 €,
But this also kepps the door open for a possible X3C for ~1600€
And not to forget, probably lower hotend and heat bed temperatures
Might be easy to port over, but the company could intentional block it to position the two in separate brackets. Software locked features, like Tesla selling a car with battery capacity software locked lower than actual capacity.
I’m looking forward to the p3c although I definitely need a chamber heater to make it worth upgrading from the p2s, as I do a fair bit of abs and PC printing. I feel like 1600 would be a bit much though putting it at nearly the same price as the h2d I think closer to 1250-1400 would make more sense or at least that’s what I’m hoping for.
I think that @Sebo3D1 did a pretty good article in the Announcement section on the H3C, asking what the user does with their 3D printer.
So I would love to know just who the Target Consumer for the P3C and the H3C is going to be. I think that that is the thing that is going to influence what is going to be on the new P3C that is different from the H3C.
I am new to 3D printing, but selected the P2S, mainly from reviews and reading this forum which is a massive help. I am an average Joe, am not a print farmer, have no real interest in printing with Engineering filaments, but am eventually going to print with TPU, and maybe ABS. But at the moment it is all PLA, and PETG. BUT I am also wanting to print in multicolour. So for me I can’t really justify the extra cost of a H3C, and hope the P3C is all that I want it to be.
So, for new users, and for the average person wanting to get into 3D printing, and wanting to print multi-colours out of the box relatively quickly will the P3C be a marketing coup for BambuLabs, and what will set it apart from others. Also, for us average users will it be worth upgrading, or best to just stick with the P2S?
Potential Pros
  • 7 Nozzles - Utilising the CMYKW colour system for multi-colours.
  • Multiple different nozzle sizes and ability to use on same model
  • Faster print speed
  • Less poop waste due to more nozzles
  • Easier access to parts that need maintaining (oil on rods etc)
  • Dedicated bypass slots for more flexible/brittle filament, including extra slot on extruder to plug in directly, to work alongside other filament
  • Filament buffer included to attach additional AMS units
Potential Cons
  • No drying in AMS - none at all
  • No Automatic spool unloading
  • No chamber heating
  • Lower maximum temperatures
  • No expansion with Sawptek (ie no DRAW, CUT nozzles)
Now that is what I can think of off the top of my head. BUT for the average/NEW user looking for an upgrade, or for starting out in the 3D print world, do those disadvantages really matter, and is it worth them going all out and getting a H3C for their first printer?? Probably not.
The problem BLB have is they have to have a fine balancing act, to appeal to new users, as well as catering for the older/print farm/experienced user alike.
The H3C and P3C are going to be printers aimed at very different people, so the more experienced people on here, who print full time, are going to want, and speculate on more features than us Average Joe types, who will be very, very happy with what is rumoured to be coming. Then later on wish they had gone with the higher end/spec model, as they want more and more as they develop with the 3D world.
I assumed 1600€ for a potential X3C.
The P3C will likely be around 1000€
Actually all the leaks points that P3C will have chamber heater, it has additional vent at the bottom as in H3C and leaked specs of H3C and P3C says that there’s heater
it seems odd though that it has the same mounting points that the p2s has where the x2d’s chamber heater is, I understand that it used a different chamber heater but the mounting points seem to point to the fact that there will be an x3c and without a chamber heater as an upgrade I feel it would be a hard sell unless it’s not much more
I was writing you my take why p3c should have chamber heater and proved myself wrong. You are right, most likely there isn’t a chamber heater, look at this, these are photos from h3c wiki and it seems they share the same ac board and there’s a blue cable that goes to the chamber heater:
And in F3C filling it’s not there, there’s not even connector:
So there either would be an addon to install chamber heater, or it would be x3c as you suggested. Most likely the second thing, since bambu doesn’t want people to deal with AC themselves.
There are multiple hints for a chamber heater on P3C.
