Startup noise
Have a look at this thread. To just stop the dynamic XY vibration check, you want to edit the startup machine gcode, and comment out the lines for “mech mode fast check”. I save it as a seperate printer settings profile that I print with most of the time, so that I can use the default one every so often to let the belt tension checks run again.
