Strange filaments show up in studio every time new model loads
Every time I load an stl into studio, the AMS filament lists a bunch of really weird filament types I don’t have. I have to sync the filaments each time. This is really annoying. Why can’t a new instance of studio read the last known set of AMS filaments half of the AMS filaments show up as ABS. All I have loaded is PLA and one slot PETG
A stl or a 3mf?
3mf files carry along all the configuration from the person who authored it, including machine, filament, process, and object-encoded properties. If you see one particularly full of weird stuff leave a note on the authors page to clean up their workspace before exporting :wink:
And be careful editing it cuz if you hit save on the profile edit dialogs… now YOU have that setting too! :slight_smile:
I did mention I’m loading STL files
It’s happening when I load STL files. Often just exported from TinkerCad
What happens if you manually (do not click a stl) run studio and switch to the prepare tab, same problem or not? If so, clear them out to your liking, save as a new project and exit.
If I open a new studio instance, it automatically brings in the weird filament settings
I fussed around with the settings menu in the filaments bar. Somehow now it seems to remember my filaments. I wish there was a “save current filament settings as default” or something similar
Did you configure it like you want, save and exit?
By “Configure” the menu has a big list of filament types with check boxes next to each. I turned off all the types I don’t use. Then I saved the blank project as “Untitled.3mf”. I think it loads “untitled.3mf” by default - but am not sure. In any case, it loads the last known set of filaments properly.
