Studio 1.9 failure and complaints list
If you ask me than Bambu went the wrong with the profiles.
Thanks for confirming by json findings by the way!
If I check my now defunct favourite, Simplify3D, or literally any other half decent slicer I find proper profiles.
Bambu however works with a staged control system.
Literally everything is mixed together on a basic level first.
E.g.: Machine configuration, nozzle type and such.
Then the filament settings are mixed in, followed by the actual print settings.
And here the issue already starts for me :frowning:
It is next to impossible to create proper filament profiles of the custom kind that Studio leaves untouched.
I use quite variety of plates/films on them, with that comes the need to have matching profiles.
Being unable to define build plate setting in any meaningful way su(ks…
But if I enter, for example “Shittament PLA dark green” and fill the profile with my settings I am happy camper.
Until I change any setting for a different Shittament roll - Studio always tries to apply what you change to all custom filaments in the AMS selection.
Quite a bummer if you need different settings for different colours, one mistake and they all end up the same.
Worse still, as you noticed as well, with the print profiles.
As I had to start from generic PLA, it is also the entire base for the custom profile.
Worse still: The internal settings we can’t see or change seem to also depend on the lay height and quality defaults of the profile you start with.
Found that out the hard way when it seemed impossible to calibrate the low ratio for a new filament.
The base profile was the 0.08 high quality one, which I selected because I know the acceleration settings and some other things work fine with my holo plates.
But I needed 0.15mm layers…
Nothing worked out no matter which way I tried to get the flow rate and k-factor honed in.
Only after starting from a 0.12mm profile I got 0.15mm working as expected.
Ideally a custom profile should be fully custom and stay that way.
Especially if someone created a profile with model specific needs.
No other printer I ever had made a mess out of things like Bambu does :frowning:
And doing manual backups of all relevant files whenever something is updated is just becoming too much of a hassle.
So I rather stick with something that works and is properly tested by users confirming it does than to jump onto every update to find out my old files no longer produce acceptable prints.
While I agree that from a viewpoint of just simplification the Bambu approach makes sense:
I am getting the distinct feeling that all this is intentional.
The filament manufacturers Bambu supports come with their own base profiles and all - which seem different in some areas to the Bambu or default ones.
On the other hand profiles a user creates only ever contain what little we can change in Studio but none of the often vital other factors.
For the user this means that once hey established a working filament and print profile it might all go down the drain with the next update.
No clue why but if a default profile changes a custom profile that had THAT setting unchanged has the updated setting applied.
Imagine, as a worst case, that ‘combine infill’ would change in the default.
That unexpected change in flow can make a total mess out of a model printed in 0.08mm layers…
I mean: What do you eventually do if you need those printer running to pay your bills?
You revert back to filaments that are already fully supported, preferably Bambu ones :wink:
i found support very hard to remove too!
I’ve also been having a ton of issues with PLA supports welding to the model after printing. Confirmed it as an issue with the new version because it’s not a problem after downgrading to the old version. Please fix
after installing the app on wibdows 11 lap top. similar behavior in mac OS it freezes at the location selection page will not install in S mode,
Previous to the update - My supports (my last roll… was pure white… just like the PLA Matte IVORY WHITE color) were fine. Then after… they where extremely hard to pull off. Not sure, I thought my setting changed - and after reading peoples reports, realized it might be the update.
Strangely enough - the new support I got “Support for PLA/PETG” it’s color is now “nature”. Which looks like the stringy rice noodles you get in a vietnamese restaurant. It’s almost partially translucent in color. However, my P1S does recognize this as support, but it won’t allow it to be used. It just defaults all supports to be the same color and material as the main body. I tried moving the Support into different bays in the AMS … but thats still not working. I don’t want to use the main color material (PLA Basic - black) as the supports also - it’ll never come off. WHY WONT IT ACCEPT AND PICK UP THE SETTINGS AND USE THE SUPPORT FOR THE SUPPORTS!!!
Begining in version 1.9.5.51, each time I open Banbu Studio, first material is always Bambu PLA Basic, no matter if I change it, or sync with the printer.
I created a print, changed the filament allocations to match and saved it.
Closed studio and it was all good.
It seems studio keeps whatever was set last and if in doubt applies the defaults rather the last used configuration.
This was fixed when updating to newest version.
