When you add the Sunlu filament, it doesn’t show up in the H2D filament list, but is shows up in the X1C list. Is that by design?
Unfortunately that is by design. Bambu has not created a filament profile for some 3rd party filaments on their newer printers.
I’m not seeing that Sunlu has created any pre-made profiles either, so your option is to use existing generic or Bambu profiles or create custom ones: Creating custom filaments in Bambu Studio | Bambu Lab Wiki
Man - they are available for other printers in the Bambu line and since they can be checked as if they were going to show up and then don’t, leads users to wasting a lot of time - espescialy when it works on other Bambu machines
If this is the case, when you select the Sunlu materials in the list there should be a warning that happens to tell the user that profiles have not been made for - the H2D printer (in my case)
With the time I just wasted I could have gotten profiles at least provisionally made. Thanks for clearing the up. Bambu? create the profiles
Get them from user JJJonesJr33 on Makerworld. I cannot post the direct link unfortunately.
User made profiles as above ^
SHAME ON YOU, BAMBU
Disgraceful
You don’t have any releases there
Looks like the creator of them pulled it down and put them on MakerWorld instead to earn points
I’ve downloaded that guys profiles for the H2X and tested them with Sunlu ABS.
Dude has the chamber temp set to 45c for ABS, I’d just make your own profiles instead of trying someone else’s half baked stuff.
BUMP
Bambu, please update the Sunlu filament settings for the H2D.
Orca Slicer has it … Loading much faster
