So I am trying to get a clean Lithophane frame, which requires supports at the very top, and if I just let it do supports and ignore small overhangs I get strings on the very front edge at top, if I enable full supports I get supports where I don’t need the so figured out hos to use modifiers to prevent the supports on the rear and only support the very top. However the issue I now have is the support is sticking to the front face of the frame. How do I move the support away while still getting the support I need? Ruined 3 frames between all three machines so I know its the slicer and not the printer.
You can manually paint where you want supports in Studio. Have you tried tree supports and check the box to only allow supports on the build plate?
I played around with the settings and did a slice on every one until I found the culprit. When you select PETG as the raft interface is automatically changes some settings. Apparently Top Z Distance moves the entire tree right into the frame. I reverted just that setting and trying another print. I didn’t notice the difference until after I ran the job on three different machines at the same time and all had the issue. So now running it on just one. I have printed about 4 or 5 before with the PETG interface but never used the support modifier to specify where I wanted supports, so they never touched before. Wasted 3 different types of silk PLA.
