Brand new to this, reading some other topics today I think I jumped the gun on buying support filament. I don’t have an AMS add-on, but since the filament hub had four ports and the Bambu Studio software lets you set multiple filaments, I thought I could just feed a support filament into the second port on the hub. Reading on here, I’m guessing that’s not possible. Am I correct?
Possible: yes.
However, you will need to do the AMS work.
It will require editing the code to add a pause to each filament swap, and you have to manually pull the filament in use and feed the support one every layer.
For a simple model and with commitment, I can see this being done… otherwise, the effort seems too high.
Thanks. I’ll see how that affects the time estimate.
So the three spare ports on the filament hub are not used without an AMS setup, I’m guessing.
I tried printing something with Bambu PLA as the model and the support, and found it to be a lot of work trying to clean the supports off the model, so I was hoping to have better luck with support filament. Looks like that’ll have to wait until I have the AMS setup.
The AMS lite filament hub is intended for usage with AMS lite; nevertheless, you can use different applications for it.
I have one AMS (not lite) - for me, it is helpful to deal with filaments unsuitable for the AMS, avoiding the tedious process of disconnecting and connecting the PTFE tubes …
The AMS is a valuable add-on to BL printers, which enables excellent features. If you have the chance, grab one.
