Hello everyone
I have a question. I saved a print plate as a 3mf file in BambuSlicer version 1.10.2. I used Normal (Auto) as the support structure. Now I opened it with slicer version 02.00.02.57, and the support structure has changed to Tree (Auto). Is this normal, or did I do something wrong? Thank you for your help.
This is normal. With the newer versions of Studio the default has changed from “Normal” to “Tree” support. You can change it back if you prefer.
Hello, thank you very much for your reply. I’ve been experimenting a bit. I followed your suggestion and set it to normal. It came out terrible.
… I get the best results when I set the base pattern to grid and rotate the support structure 45 degrees.
I have no idea why I’ve seen such differences in quality since the update.
