I am trying to bring in a .svg file to Bambu studio when I do it looses all of it color, how do I fix that?
Studio doesn’t make any use of color data in SVG, only the basic geometry to create shapes. There’s no “fix” per se. But there may be other ways to accomplish what you wish to do – whatever that is (let us know).
-Max
PS. Typically to assign colors after importing SVG one needs to split the result to parts and assign filaments manually, eg. as described in the wiki. Or paint onto the resulting model.
What is the best file extension to bring into Bambu Studio that will keep the color? Thanks for answering!!
Only actual 3-D models in either 3MF or OBJ format will preserve any coloring on import (technically those are materials applied to the model in the original modeling software).
If you’re trying to convert a 2D image to a 3D colored model, there are definitely much better tools out there than Studio. Such a tool would create a final 3D model which you’d then import into the slicer (with colors).
In fact most CAD/CAM software could do a better job even from an SVG – the slicer isn’t really a good modeling environment. But there are also specific tools (mostly online, some free, some not, lots of AI-assisted stuff, varying between producing jank and impressive actually-printable models, sometimes depending on the input). If you post more details, perhaps someone could recommend something more specifically.
Cheers,
-Max
Thank you this is very helpful info!
Cheers,
Carolen
